Results 1 to 4 of 4
    Jan 2018
    Default Mercedes Sprinter 515 CDI DTC off EDC16CP31
    Hi guys
    I would like to do a dtc off on a mercedes sprinter 515 CDI.
    EDC16CP31.
    2011 - Mass air flow meter, flow rate too high
    - Permanent
    and it goes into limp mode,I already change the maf sensor and initialize it but it's always the same.
    2013 - Temperature sensor display, CAN signal fault
    - Permanent
    Thanks in advance,
    Dec 2013
    Holland
    Try dtc 2011 and 2013 off i think you have still limp but try
    Quote Originally Posted by SR71 View Post
    Hi guys
    EDC16CP31.
    - Permanent
    - Permanent
    Thanks in advance,
  3. The Following User Says Thank You to jelmer52 For This Useful Post:
    SR71 (17th April, 2018)
    Jan 2018
    I will try and report.
    Thanks !
    Jan 2018
    Thanks !
    I tried the file, and as you predicted there is no more DTC but the limp mode is still there.
    I will look for another solution.
