Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    Sep 2008
    Default op com firmware 1.39?
    does everyone have firmware 1.39 for opcom?
    Dec 2014
    PL
    Hi.
    Firmware 1.39 is needed for cooperation with OP Com China Clone 082010. After being used with the Vaux Com 2014 software, firmware will be automatically updated to version 1.45. There is one condition. The Opcom interface must have a programmable PIC 18F458. If it is not programmable then the opcom will be damaged.
  3. The Following User Says Thank You to Mario6 For This Useful Post:
    raster ozi (2nd June, 2021)
    Dublin Ireland
    Default firmware 1.39
    Firmware 1.39
  5. The Following 40 Users Say Thank You to gerinemo For This Useful Post:
    707dave (20th June, 2019), Adiadi (14th August, 2020), ajc123 (30th September, 2019), art13 (23rd March, 2020), bar72 (9th March, 2023), bbounce (25th February, 2019), beerling20370 (5th November, 2021), BigJ (24th December, 2018), carcode (2nd May, 2020), Choko67 (28th December, 2020), clickerfux (9th March, 2022), Col19 (17th November, 2019), donatasslaustas (27th June, 2022), dustix22 (4th May, 2022), fricis99 (15th January, 2021), ggk55vd (4th December, 2019), Giorgos213 (8th June, 2023), Gurbettekises (9th February, 2022), hector3 (27th February, 2020), Joe068 (7th April, 2020), johnnyk12 (10th November, 2022), kronk92 (2nd April, 2022), madafak (4th November, 2022), mijatx (4th February, 2022), MikeDinis (29th March, 2022), mylus (25th April, 2021), nekulay78 (26th September, 2023), orrie89 (17th November, 2020), pincky1994 (8th May, 2021), ProblemChild (28th July, 2022), rankan (7th July, 2021), sarigol45 (28th June, 2022), sep382 (27th November, 2021), Toldy (4th March, 2019), tyrossie (24th May, 2023), Unrealator (7th March, 2023), walge (17th April, 2019)
  6. #4
    Nov 2011
    hi all.can someone tell me wich version of opcom is best to use for reading security codes from opel ecu,s?Thanks in advance for your answers.
    Mar 2019
    thnx
    gerinemo
  8. #6
    electronistul21's Avatar
    Nov 2011
    galati,romania
    opcom can read codPIN only to Corsa C.For this need use opcom with FW 1.39
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  9. The Following User Says Thank You to electronistul21 For This Useful Post:
    Col19 (11th January, 2021)
  10. #7
    Sep 2019
    Quote Originally Posted by gerinemo View Post
    Firmware 1.39
    Thanks very much for this!
  11. #8
    Jul 2017
    Default Will this fix my cluster communication problem?
    Firmware 1.39
  12. #9
    Mar 2020
    leicester
    is it possible to download op com FW 1.39 or I get divorced
  13. The Following User Says Thank You to cojna For This Useful Post:
    Mk developments (3rd January, 2023)
  14. #10
    Apr 2020
    thanks been looking everywhere for this
  15. #11
    Dec 2020
    gfhfyjgjgjgj
  16. #12
    Aug 2020
    FW 1.39 thanks ,
  17. #13
    Mar 2021
    Default Cheers for the FW
    Quote Originally Posted by nahok View Post
    FW 1.39 thanks ,
    Thanks for the FW
  18. #14
    Dec 2019
    Many thanks for this firmware I have been looking everywhere for this. I am using what I think is a !.7 version of device, (it has the white wires wires internally and a proper pic chip). I am using it on a 2011 diesel turbo 1.3 Corsa D and 1.65 firmware with windows 10, interface test ok but cannot read ecu parameters although other modules are ok. Can reset error codes though, and have tested OBD socket with multimeter and is correct (60ohms and correct voltages) I will flash this FW and see if it works any better.
  19. #15
    Dec 2014
    PL
    Quote Originally Posted by Castrol R View Post
    Firmware 1.39 is designed to work with SW Opcom China 082010 and lower. If you have Opcom China clone with real PIC 18F458 and you use SW Vauxcom 120903a your FW will be automatically changed to 1.45. .
  20. The Following User Says Thank You to Mario6 For This Useful Post:
    760621 (7th June, 2021)
