    Jan 2018
    Budapest
    Default Citroen C3 Pluriel 2003 Siemens BSI Tool
    I need help to find a tool to dump/correct milage on Siemens BSI of a Citroen C3 Pluriel - 2003. Unforunately FVDI support only 2004+ BSIs.
    Could you please help me to find a solution!
    Thank you in advance! Waiting for your kind feedback!
    Thanks,
    Zoltan
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    you´ll need a prgrammer like orange5, xprog, carprog, and so on... it´s equal... with them you can first read eeprom... calculate/correct mileage (wth another programm like fvdi...), and write it back to eeprom and so on...
    I think (maybe I´m wrong) there exist no obd solution for this kind of car/type....
  3. The Following User Says Thank You to figani For This Useful Post:
    juggleres (20th April, 2018)
    Jan 2018
    Budapest
    Thank you! I am a lit a bit sad, that OBD solution is not available.
    Thank you for your help again!
    Apr 2018
    brazil
    Você pode fazer programação com pp 2000
    Nov 2017
    Indonesia
    read with eeprom programer, i thinks its cheap. and you can read without ddsoldering. use good clip. after read dump. i can adjust milleage. just post dump
    Nov 2017
    Indonesia
    if i not wrong. its use eeprom ST95160
