Results 1 to 11 of 11
Hybrid View
    Dec 2009
    Default Iveco daily edc17 dpf
    Hi, it is possible to delete error from dash? I removed dpf and have error on dash ( Particular filter clean incomplete )
    I try to reset DPF service before writing flash but after error is back. In ecu I dont have errors and engine lamp is off.
    did smeone have good solution for dpf off.
    Here is org flash edc17,
    THANKS
    Dec 2013
    Holland
    Quote Originally Posted by carbyvw View Post
    THANKS
    Try this all dpf is off
  3. The Following User Says Thank You to jelmer52 For This Useful Post:
    carbyvw (18th April, 2018)
    Dec 2009
    but this solution from DPFremover already tryed and have same problem.
    Sep 2009
    here u have pass pm
  6. The Following User Says Thank You to mb7361 For This Useful Post:
  7. #5
    Dec 2009
    same problem,Particular filter clean incomplete
  8. #6
    furnata's Avatar
    Feb 2010
    Bulgaria
    its EDC17CP52 or C49?
    i saw it its c49 here your file
    pass PM
    Im here to help and to be helped
  9. #7
    Dec 2009
    Rzeszow PL, Linden NJ USA
    Default mitsubishi cantar fe-125 EDC17CP52
    hi guys i have a usa market 2011 mitsubishi cantar FE125 3.0d. with edc17cp52, need egr and adblue off . if possible leave dpf on, if not everything off,
    thx
  10. #8
    Sep 2016
    Poland
    after edit software must use diagnostic tester to reset dpf than write dpf off.........
    FILE SERVICE
  11. #9
    Mar 2010
    TURKİYE
    ıveco aifo 8210 manual pls
  12. #10
    jurebv's Avatar
    Dec 2017
    Croatia
    With what do you make dpf reset???
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  13. #11
    immokill's Avatar
    Jun 2009
    UNIVERSE
    You must first teset oil reset dpf with diag i do it with brainbee and then write file dpf off . Maybe if not ok reset oil again . Did it befire all ok.
    Sent from my TELEFON
    Here to HELP!
