yeah is deffo to do with maps ghe tuning map no error nor no limp mode?
hello is it possible to convert a map to run on uprated map sensor?
with old map and old uprated turbo no implausible map error
now with original tuned map implausible map error and limp mode
i can only put this down to uprated map sensor?
please help shed some light
ghe tuning map is old map made for bigger turbo
try this and report
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
kennyash1 (19th April, 2018)
still implausible signal.. thanks though
what is changed on ghe tuning map pressure sensor work fine on ghe tuning map? not on original ecu file map.. what have they changed?
no in ecu remaped work but in ori can't ,i modified just moded map
reset mesages in pm i can't send you
File Service
i have pmed you buddy if you can help me it would be amazing!
this is another too try will work i hope
File Service
If you need working solution pm me
fixed it guys! I found what values needed to be changed!
from any map if I change the values to 4000 instead of 2689 I must have 4 bar map?
