Results 1 to 1 of 1
    Jan 2018
    shaftesbury,Dorset,UK
    Default help fix N75 Duty cycle
    Hello again
    Further to my issue I have found out its a n75 duty cycle issue which would make sense..
    on my 2.5 v6 ecu I cannot seem to find the n75 duty cycle map not like on various 1.9 tdi ecu....
    I need stock turbo n75 values on modified map because I used to have better turbo and it died so replaced with stock turbo I have detuned the file but when boosting it will constantly like spike and actuator makes noises like its cutting is it possible to put stock n75 values into modified map?
    also n75 duty cycle needs to have 3 bar map in mind
    hope this makes sense! this problem is killing me!
