Results 1 to 15 of 17
    Nov 2011
    EU
    Default Renault Master 2.3 dci dpf egr off
    Help with dpf off + egr if also can be done
    Master with edc17c11
    p2002
    p2263
    p1650
    p047b
    Nov 2011
    EU
    I know only how to disable dpf by switch, by I would like also disable dtcs.
    johak's Avatar
    Quote Originally Posted by bugarcek View Post
    here is these dtc off, if you need to delete other write me
  4. The Following User Says Thank You to johak For This Useful Post:
    bugarcek (19th April, 2018)
    Nov 2011
    EU
    Here is file with working egr off, can someone make good dpf off here
    Bulgaria
    5A FF 7F 00 00 01 00 00 00 00 01
    5A FF 7F 00 00 01 00 00 00 00 00
    did you try with this switch ?
  7. The Following User Says Thank You to emiliogsm For This Useful Post:
    bugarcek (3rd May, 2018)
  8. #6
    Nov 2011
    EU
    Yes I tried this. Should this be enough?
  9. The Following User Says Thank You to bugarcek For This Useful Post:
    ayllon308 (25th April, 2021)
  10. #7
    Nov 2011
    EU
    Hi... This car will kill me... Still not okay...
    Switched egr off with unpluged solution....
    Car goes like a hell and than at full loads turbo stops working for few second and tahn goes again... But there is no engine lights and you do not need to stop and start car to get power back... This happens at full loads 100kmh...
    Dpf off is made by switch and there are also dtcs deleted by johak method... What else could also be a problem?
    Can be limp mode turned off, or maybe dpf is not turned off well because of faulty sensors?
    Please if someone can check
  11. The Following User Says Thank You to bugarcek For This Useful Post:
  12. #8
    johak's Avatar
    write this, disconnect egr and see what's happening
  13. The Following User Says Thank You to johak For This Useful Post:
    bugarcek (12th May, 2018)
  14. #9
    Nov 2011
    EU
    Same... car goes like a hell upto 4th gear.... Than problems at revs from 2700-3200, dead... Like there is no turbo.
  15. #10
    Netherlands
    Measure the fuel pressure while driving, sometimes the pressure drops to much on full load.
  16. #11
    Nov 2011
    EU
    here I get totally original file... It seems that car was tuned or something. Car still not solved... Changed fuel filter, than injector and high pressure pump...
    Can be here done egr and dpf off?
    Thank you guys for all help here. Car is like a devil
  17. #12
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Here you DPF and EGR off file.
  18. The Following User Says Thank You to Inquizit0r For This Useful Post:
    bugarcek (21st May, 2018)
  19. #13
    Nov 2011
    EU
    Now I get this error: p2263 df569... What should be?
  20. #14
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    you should take good solution for this
    DSG TUNING
    File Service
  21. #15
    Nov 2011
    EU
    I made wrong when I asked for deleting this pcode... That is why I was walking in the darkness... And with ori map and normal dpf egr map I get this error for turbo. Now I know that turbo will need repair. Thank you guys for all your help.
