Citroen Berlingo 2014 edc17c10 dpf additive pump remove
Results 1 to 5 of 5
    Jan 2013
    95
    Downloads
    3
    Uploads
    Default Citroen Berlingo 2014 edc17c10 dpf additive pump remove
    hello
    please i need remove dpf additive
    ECU 0281030548 ECD1710
    READ GALLETO
    thank you in advance
    sdtsedat's Avatar
    Jan 2015
    Belgium
    200
    Downloads
    6
    Uploads
    Here,
    DPF + Switch + DTC + Additive pump removed
    Pass sended on PM
    ​Original Kess V2 + CMD + Autotuner + Winols + ECM geniune owner
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2
    Diesel + petrol
    Belgium
  3. The Following User Says Thank You to sdtsedat For This Useful Post:
    obd2maroc (19th April, 2018)
    johak's Avatar
    155
    Downloads
    18
    Uploads
    here you go
    If I helped you and want my help the next time,
    don't forget reputation and thanks buttons​ !
  5. The Following User Says Thank You to johak For This Useful Post:
  6. #4
    Jan 2013
    95
    Downloads
    3
    Uploads
    hi
    please pass
    Jan 2013
    95
    Downloads
    3
    Uploads
    thank you very much
    work good
