Results 1 to 12 of 12
    dominik.m's Avatar
    Jun 2009
    POLAND
    Default VOLVO V70 2.4D D5
    Hi All.
    Need Your help.
    VOLVO V70 2.4D D5 2008r. 0281012765 30785100AB
    I tried to remove DPF for help swiftec, but not work.
    There are no DTC , nothing shines ,but car is still limp mode.
    Somebody can help correctly remove DPF.
    Thanks.
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    which ecu edc17 or edc16
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    dominik.m's Avatar
    Jun 2009
    POLAND
    It's EDC16.
    Nov 2015
    TRY THIS
    PASS PM
    AVDigitale's Avatar
    Apr 2017
    dpf-dtc-switch off pass in PM!
    try and report
    File Service
  6. The Following User Says Thank You to AVDigitale For This Useful Post:
    dominik.m (19th April, 2018)
    dominik.m's Avatar
    Jun 2009
    POLAND
    Thanks for help. I'll test and report.
    Sep 2016
    this easy because car have emergency mode, you have destroy temp sensor and you cut dpf swiftec or other but they not emulted this sensor so car still not drive. Simply
    FILE SERVICE
    Sep 2016
    this is my manual solution, manual cut dtc no shit automatic software which cut 30 % DTC !!!!! no cut emergency mode. If you like disconnect temp sensor and differetnial pressure sensor.
    FILE SERVICE
  10. The Following 2 Users Say Thank You to voltechcar For This Useful Post:
    AVDigitale (19th April, 2018), sdtsedat (20th April, 2018)
  11. #9
    Apr 2016
    If you have no sensor damaged a single switch solutions is enough.
    Here it is for you.
    Br.
    Michael
  12. #10
    dominik.m's Avatar
    Jun 2009
    POLAND
    AVDigitale. Your solution is good.
    Thanks.
  13. #11
    darwins's Avatar
    UK
    Can I have a tested DPF removal for this please.
    POST CLOSED.....
    Go for it. The future is promised to no one
  14. #12
    darwins's Avatar
    UK
    It seams solutions are chargeable these days, maybe admin could add a charge function " BUY IT NOW " to speed up the process
