Results 1 to 10 of 10
    Aug 2009
    Hampshire
    Default ford galaxy help please
    hi guys
    went to add a key ,which the chip was lost from the remote,2001 petrol 2.3 ohc engine ,connected my tester,but i couldnt get any comms under any system,does any one know what to check for comms failiure?.
    any help is greatly apreciated.
    naz2
    Quote Originally Posted by nazz2 View Post
    hi guys
    naz2
    If you know that the tester you're using is OK, the first thing I would be checking is the wiring to the DL-16 plug.
    Check Here for wiring details.
    Aug 2009
    Hampshire
    hi
    thanx for the info,but im not very good with cars electrics!,is there any fuses or relays which could cause this?can it be a locked ecu or immo?any tip is greatly apreciated.
    nazz2
    Sep 2009
    Can you connect to other ecu's? Like Airbag or ABS?
    What tester are you using?
    hi
    nazz2
    Then leave it alone FFS
    If the car starts and runs (which I assume it does as you didn't say otherwise) then the problem is likely to be in either the plug or the tool mate.
    obdmaster's Avatar
    Never never land
    Smile
    Pretty sure on this vehicle an aftermarket radio can cause communication problems, try unplugging radio and try again.
    Aug 2009
    Hampshire
    canno,if you read the thread properly,i have said that the guy has lost the chip!so i dont think the car runs with no chip!
    also i havent got the scanner just i keys,,key programmer,so cant get any comms what so ever to check any code.
    the radio is original ford,so nothing has been done to the car prior to the loosing the transponder chip,basically what do i need to check for no comms?thnx
    nazz2
    nazz2
    At which point did you say it didn't run ?
    At which point did you say you only had one key ?
    You said you couldn't get comms so I posted a link to help you understand and check the layout of the EOBD socket, then you say you don't have a scan tool and have a go at me for trying to help.
    AT this point with no scan tool and being no good with car electrics then send it to a garage !!
    Aug 2009
    Hampshire
    mate at one post you say leave it alone if i dont know about car electrics,well i that dont know im a qualified auto locksmith,but if you give advice,which is apreciated,anyone knows the car(specially fords)engine wouldnt crank if the chip is missing!so lets leave it at that.
    today i went to the car and spotted a new bat and alternator,which means that the car has had some history of not charging maybe,and you know if they use the jump leads,that could spike the ecu.since the customer never tell you the whole history,i think thats probably the cause of no comms,i advised the customer to take it to ford.
    i didnt mean to be unapreciative,hope you undersatnd.
    nazz2
    Meat-Head's Avatar
    Had one in the summertime when the weather was fine, just selected (can't remeber excat words) 'resync immboliser' and it started
