bad edit dpf if you have P1902, If you edit file ads this solution not work in this car and cut 50% dtc table.
Hi people,
I flash today 10times a Saab 9-5 1.9TID 150hp with edc16c39 remap, but car is always smoke.
With original smoke is little, i cut DPF manual and removed in map, also egr.
I have now Check engine light with dtc P1902, someone can cut this DTC?
I am also happy if someone can make remap WITHOUT smoke so i see what i do wrong...
attached file egr and dpf removed, only need DTC P1902 and remap without smoke
Someone?
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
FILE SERVICE
Did You do the log before and after remap? 90% you have leaking boost through swirl flaps. Remove the plastic cover of engine and check if there are no oil on swirls.
If it is, only mechanical blank with special blanks or welding of them will help you to avoid smoke.
pfff no one can help me...
Only cut dtc P1902???
I help every people here, and tnonow i need help but no one help me.
Thank you DK members
Sedat Garip
Belgium
With Kind Regards,
I think xCata asked for ori file to be able to help
this file works. no need cut dtc and no have dtc p1902
FILE SERVICE
sdtsedat (23rd April, 2018)
Very very thanks! I try today and hope this is last time that i flash this car
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Belgium
With Kind Regards,
