Page 5 of 13 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 192
  1. #61
    Pinout for Bosch MED9.1 and MED9.5.1
  2. #62
    has somebody bdm connections for simens sid 803?Connection pads in ecu is not the same like EDC 16 and this adapter not pased!Thanks
  3. #63
    joined to england by a small piece of land
    Don't know if this will help but there is a manual on the site below with pictures of connections to different ecu's.
    evc.de/en/download/down_bdmtogo.asp
  4. #64
    Quote Originally Posted by eglo View Post
    Even if the clone it's called a BDM100, it's not from EVC. The clone is a copy of the BDM made by CMD for DimSport. Now, the newest ones seems more a direct copy of the CMD, it's hard to know.
  5. #65
    Quote Originally Posted by exxl View Post
    @dod
    watch out, not all china clones are the same clone and same connection, you have a clone that connection goes on reversible side.
    my clone the connection goes like original bdm the red line on flat is the first pin.
    here is a picture
    Where did you bought it ? Since, I would like one without the need of external power supply.
  6. #66
    Bought our BDM through EVC along with WinOls. Works perfectly well and has done since we bought it 5 years ago. When you buy equipment from China you get exactly what you pay for. The stuff is crap and unreliable for a good reason.
  7. #67
    France
    Quote Originally Posted by Tommy123Tommy View Post
    With this you can update all china clone bdm 100 to 1255c, that means versions 1236 1242 & 555pro
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    you must have your working version installed on your pc
    then you need to run 1.EXE then 2.EXE with your tool conntect to the usb .
    If that not work run 2.exe and then 1.exe
    it also includes the 1255c
    100% working .
    Dont forget to say thanks .
    Link not work! please send...
  8. #68
    France
    Merci youyou, c'est Mickass du forum Chituners.org...
    A+
  9. #69
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by Goups View Post
    But indipending EVC or CMD,the SPI pad on ecu is same for all...it depends from ecu producer,not BDM...so you can use manual from evc,which is really great one even if used an CMD or clone BDM
  10. #70
    Top Poster youk's Avatar
    france
    salut mon amis
  11. #71
    thanks good sharing for us
  12. #72
    Aug 2010
    3ryhwr gvfbwr b
  13. #73
    Hello, I have cmd can flasher 1251 (obd2)
    I tried to update to 1255 version from this forum but no succes. when I run 1.exe and 2.exe I get "error opening device".
    what drivers should I install?
  14. #74
    Moon
    Does clone BDM100 read and write the same ecu's as the original BDM? I want to buy one and want to know if it does the job. Will mainly use it as second option for edc16.
  15. #75
    Newbie dr wox's Avatar
    I decide to build BDM100 for me, so first step is schematic. It differ in small things to well known design, but pcb will be quite different.
    Regards,
    "si tacuisses, philosophus mansisses"
