Results 1 to 12 of 12
    Oct 2015
    Default BMW E60 2004 Battery drain
    Hello everyone,
    I have problem with a BMW E60 2004 3.0L diesel, duing the night battery drain. I have check the wire and all looks OK. I have change IBS (intelegent battery sensor) from another car but nothing, same thing, battery drain again. When i remove fuse 29 (10A) everything is OK. Or when i disconnect AIRBAG ecu everything is OK. But i have try with other AIRBAG ecu and the same thing. Please any idea for this problem ?
    Jun 2010
    as airbag ecu do you mean SGM? Safety Gateway module, under the glovebox? What errorcodes do you have?
    Meck's Avatar
    Jun 2016
    Bosnia, Tuzla
    check the airbag in the doors that is the trouble on that cars with battery drain
    Chip tuning custom Stage 1 2 3 egr, dpf, dtc, hotstart lambda etc...
    24/7 Online support
    Skype name on my profile
  4. The Following User Says Thank You to Meck For This Useful Post:
    evisdaci (24th April, 2018)
    Oct 2017
    CHeck the big resistor that regulates the fan for air inside the car!!! changed lots taht were draining battery!
  6. The Following User Says Thank You to autoSP For This Useful Post:
  7. #5
    Oct 2015
    I think i find the problem, i unplug another AIRBAG ecu it is under gearselector and now looks OK. Because this car have another ECU under the glove box thats AIRBAG ecu (big ECU with optic cable), but when i unplug that windshield wiper start working and some other anomaly. Now i find another ecu under gear selector and when i unplug everything looks good.
  8. #6
    Jun 2010
    that fuse is for SGM and its the one under the glove box. Check the error codes...
  9. The Following User Says Thank You to ptikkala For This Useful Post:
  10. #7
    Oct 2015
    The problem is not solved. After remove the airbag ecu under gear selector i see the same thing again. For moment it looks good but the same problem. When i measure with digital multimeter the amperage drain is 7~8 Amp. Only when i disconnect SGM module the amperage drain in 0.35 Amp. I have disconnect some ECU but same problem, only when unplug SGM module i have no problem with drain battery
  11. #8
    Oct 2015
    I solve the problem, the problem is in Steering angle sensor. This ECU drain my battery
  12. The Following User Says Thank You to evisdaci For This Useful Post:
    tomushas (10th June, 2021)
  13. #9
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by evisdaci View Post
    i have same situation in mine E65, also sterring angle sensor drain battery..
    Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
    DSG TUNING
    DPF / EGR / TVA / SAI / Lambda
    Crackle map ( Launch Control + No lift Shift + Antilag )
    File Service
    PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
  14. #10
    Oct 2020
    I'm having the samr problem with my e60. Csn you please explain how you solved yours
    I would really appreciate your help.
  15. #11
    Oct 2020
    Please can you help me? Im having the exact same problem
  16. #12
    Jul 2019
    far far away
    guys wrote - steering angle sensor. unplug it and check what drain u have
