Results 1 to 10 of 10
    Oct 2015
    Default Peugeot 308 2010 1.6 petrol Lambda off
    Hello , please help me for Lambda off or DTC off solution this car.
    Peugeot 306 2010 petrol BOSCH med 17.4 0261 505 626
    DTC P0054 downstream oxygen sensor resistance fault resistance too high
    DTC P2196 Information on the mixture between the upstream sensor and the downstream sensor coherance
    DTC P2270 Downstream oxygen sensor signal fault coherance
    Thanks Advanced
    Best Regards
    johak's Avatar
    try with this and report
  3. The Following User Says Thank You to johak For This Useful Post:
    boroda75 (11th April, 2019)
    Oct 2015
    Thanks please send me password
    Aug 2018
    Default Peugeot 308 2008 lambda off non cat.
    Hello guys!
    Need to disable the lambda probes after cat. & non-cat (Euro-2)
    and errors P0172 P2178 P0139 P0054 P2192
    ecu med17.4.2
    HW 9665291180
    SW 9663193780
    Upg SW 9677572780
    Flasher KESS v.2
    pike's Avatar
    Sep 2013
    Hi, there is such solution, you can disable lambda2.
    Aug 2018
    How do I send a file with stock data?
    Feb 2019
    Adygea
    Quote Originally Posted by johak View Post
    Feb 2019
    Adygea
  10. #9
    Spain
  11. #10
    Feb 2022
    Default lambda of Peugeot 308 med17.4
    Hi can someone please help a lambda of Peugeot 308 med17.4 o2/lambda please
