If you dont want to brick ecu, do this by bootmode
Verstuurd vanaf mijn SM-G955F met Tapatalk
Hi friends, i need a Tuning for this BMW.
You can Help me? is this a file with TP Tuning Protection? or can Flash with Kess V2 this file on the ECU?
The car hafe a Manual Gearbox.
HW: 07810000
SW: 1037391387
VIN: WBAVU51030A309264
SW Ver.:
Teile: 07810007
Motor:
HW Ver.: 0281015075
SW Upg.: 07810027
Anlage:
thank you
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
voltechcar (25th April, 2018)
This sw 391387 are safe obd, you can read/write with no problem.
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
maajkii (25th April, 2018)
okay thank you
i need now correct tuning file
This is from my car same ecu edc17cp02 from 2007..
Trust me i have tested much much things. Best way bootmode, no matter wich sw.
Only autotuner can do this safety by obd.
Fgtech dont brick ecu, with kess all ok and car no start
Sedat Garip
Belgium
With Kind Regards,
I hafe Kess v2, and no work with him with Tricore Mode
in this ecu edc17 only boot mode,you first make a read in boot mode,after you can make tricks to read and write in obd if fail after you have bood read
best regards!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
