Results 1 to 10 of 10
    nizarben's Avatar
    Dec 2013
    Default calcule checksum
    hello
    anyone calculate checksum md w204 dcm3.2
    thxMB dcm3.rar
    Mar 2013
    Europe
    When you use Kess V2 or Ktag, he Calculate Checksum for you
  3. The Following User Says Thank You to bersch8688 For This Useful Post:
    nizarben (27th April, 2018)
    nizarben's Avatar
    Dec 2013
    yes but when I do with ktag the car starts once and after it starts more, with the original file it works well, I think the ktag does not calculate checksum for md dcm3.2
    LaraVAG's Avatar
    Jun 2011
    CRC in your file its 100% correct
    CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
    EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
    DTC OFF, LIMP HOME MODE OFF!!!
    ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
    HOT/COLD START
    CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
    TRANSLATE DAMOS ENG
    COUNTER FIX - VAG EDC16, EDC17
    ORYGINAL FILES DATA BASE
    START/STOP ON/OFF
  6. The Following User Says Thank You to LaraVAG For This Useful Post:
    nizarben's Avatar
    Dec 2013
    so what is the problem in your opinion?
  8. #6
    Feb 2017
    post original file
  9. #7
    nizarben's Avatar
    Dec 2013
    Default file original
    here original file
    ori.rar
  10. #8
    kamsky's Avatar
    Oct 2017
    http://mhhauto.com/Thread-Delphi-CRD...internal-error
  11. #9
    nizarben's Avatar
    Dec 2013
    this method does not work as well
    I put flash ori she does not start I put micro ori she does not start, but when I add the eeprom the car starts, I think there is something that touches leeprom when I put mod file
  12. #10
    Who calculates the checksum in delphi CRD. 11 ?
    If it flashing only MPC car not start.
    oryginal files is OK.
    link https://mega.nz/#!FIpAGYjK
