Results 1 to 13 of 13
    Bosna
    Default Mercedes vito 2.2 edc16c2 dpf
    Hi, pls dpf off, vito 2.2 with bosch edc16c2 ecu.
    Need tested manual solution, so pls don"t send me file for test.
    wbr
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by mvekaz View Post
    wbr
    disconect your temp and diff press sensors from dpf....file tested
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  3. The Following 2 Users Say Thank You to teamtuner For This Useful Post:
    bobolin4o (30th April, 2018), diagprog (28th April, 2018)
    Bosna
    Testing phase. I"ll inform you about result.
    Thank you.
    Bosna
    Test over. Everything was fine until check engine appear on dashboard. Car lost power. Check dtc with diag. P2641 in error code memory. What is wrong?
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    you have not disconected as i said the temp sensor and diff press sensor...please do it
    outside forum:
    Bosna
    You are in right, just disconnected diff pressure sensor but not temp. sensor. I"ll do it. Second testing phase underway.
    By the way, about what is P2641 DTC?
    Bosna
    After second testing phase I have same situation. Car lost power, after ign. off and on, you can drive car normally.Read DTC, P2641 stored in error memory.Temp. and dif press. sensors disconected.Any suggestion.
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    P2641 is for Back Pressure Sensor.
    It is not DPF related!!!
    Check and repair...
  10. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    mvekaz (8th May, 2018), pike (9th May, 2018)
  11. #9
    Bosna
    Ok , I"ll check it.
  12. #10
    Bosna
    After long time test same problem, DTC P2641-Exhaust Gas Pressure Sensor, car goes to limp mode.
    Diff. and temp. pressure sensors disconnected.
    Change back pressure sensor, same thing.
    Ok, make some tests, disconnect back pressure sensor, new DTC appear P2089- Back Pressure Sensor , so P2641 is not related to back presser sensor.
    What is wrong?
  13. #11
    bobolin4o's Avatar
    What is wrong?
    Wrong is your knowledge...
  14. #12
    Bosna
    t's a bit confusing.
    P2641-Exhaust Gas Pressure Sensor.
    P2089- Back Pressure Sensor.
    Car is friend of mine, he work with delphi-autocom diag, not with DAS or KTS.
    Never mind.
    Anyway to remove DTC P2641 to try.
    And thank you for your effort.
  15. #13
    bobolin4o's Avatar
    Simple removing of this DTC will not solve the Limp Mode.
    You must to find the reason and resolve the problem!
    Regards!
  16. The Following User Says Thank You to bobolin4o For This Useful Post:
    mvekaz (29th May, 2018)
