Post your bad file here...
Here is the bad file.
Bad read.
What tool are you using?
Read eeprom 95128
Нужна помощь, чтобы очистить код аварии 98820 9NG4A EP 95128.
Спасибо
кто может помочь очистить дамп?
your clear file,report back.
thx.
Regards. I need your help.
SRS Airbag Bosh
98820 9NG4A
0 285 012 590
TMS470
eeprom 95128
I fixed it myself. Please check.
the "Airgag" lamp goes out and comes on again. the "Launch" diagnostic says there are no errors.
jenya (24th September, 2020)
Thank. Your dump works the same way. The airbag lamp goes out and comes on again. The Launch diagnostics show that there are no errors. I am reading and programming with a TNM5000 programmer.
Your dump behaves the same. I stitched the crash dump back into the block. diagnostics show the presence of a crash
Try this and report.
jenya (6th October, 2020)
The airbag lamp goes out and comes on again. The Launch diagnostics show that there are no errors. I myself see this for the first time. the lamp goes out and then turns on again.
And this option did not work either. the same password
