When you solve everything please post detail procedure. I just dont understande anymore is my problem amp or something else in the line?! is there a chance that something else is a problem?! This Bose is complete shit
Just keep informing me about your progress. Thank you very much
So I'm done
!! Attention !! Woofer have two coils 2+2ohm. OEM connection is paraller into 1ohm. I need 2ohm at least, but Audison have too much power to 2 ohm (550W RMS) so I had to make serial connection into 4ohm . I did it on subwoofer harness in trunk like this:
Sound is now unbeliveable. I have Hertz Uno speakers ("entry level") K1656 + X165. Hi-Pass activated (around 70Hz) so for bass frequencies is subwoofer only. This setup makes very clear and legible sound with many details. Bose woofer is lower quality as whole system , but with Lo-pass filer (around 80 Hz) without boost is usable ;-)
Can you post detail "how 2". I would like to do the same but the pictures dont tell too much. I am willing to pay. Please help
Hi Guys my bose amp model is GS1E-66-920A I have the same issue at the beginning I used to hear machine gun sound then I lost the entire sound no sound at all,
so I changed the following chips but still I got no sound at all:
- NCV8141 (it looks burn)
- ST2L05-3300
- CS42438
- SCB56374AEB
What should I do? Any Suggestion please
Hy to everyone , in hope to be someone here who have any ideea but a right idea with this amp I will post my question and my experience solution here with you. I have on my workbench Bose BBM2 66 A20 this am sounds up my friend's mazda , I try to powered up with power supply and I hear like all of you gun noise , I replaced the dual voltage stabilizer and the DSP and after that doesn't work but actual symptoms are next : the current consumption is 0.9A in free run and the TDA8595 come to be hot . I don't understand what can you do for next step to finish and put back in work.
I did the repair of Bose GDL1 66 A20 according to the previous instructions and everything worked fine.
After a few hours it was no sound.
The DSPB56374AE component has burned out but the voltage regulator is ok.
But I replaced the three components again.
On the bench (GND, 12V and Remote on with 12V), I have a consumption of approximately 0.9A and the TDA8595 (291618Cu) is very hot.
Is it normal or do I have a damaged TDA8595?
Thank you for your help.
The my Amp can't turn on because it doesn't have 12 v active same picture .how can I repair it? I am thinking the pcb is broken line but I can't find it.
I have the same problem. Hopefully I can solve it too!
Hi All,
I already repaired a few of these amplifiers.
In most cases by replacing LDO, DSP and ADC/DAC.
But currently i have a MX-5 model (NH61 66 920) which has no sound.
The WDI signal was not OK, so replaced the DSP + LDO
Now the WDI is Ok and i can see Data reading from EEprom during startup.
Reset is pulled High: OK
DSP clock: OK
Serial audio coming from ADC to DSP: OK
Serial audio from DSP to DAC: NOK
Replaced the CS42438: Same result
I replaced the DSP 3x (from same aliexpress delivery), but start to have a feeling these chips are not working....
Anyone having other ideas ?
If someone is interested, i have following original EEprom files:
GS1E 66 920A (MAZDA6)
NH60 66 920 (MX5)
NH61 66 920 (MX5)
Hi Rockyenco,
Do you perhaps still have the EEPROM files for the NH61 66 920 Amplifier, as I think the code on my unit has somehow been corrupted?
