Hello
adblue tank and module are one block,located near fuel tank !
Hello
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
ZAHEER (1st May, 2018)
thanks mat
I can do edc17c60 adblue off
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
many can do it.
if not solved I have Solision This ecu !
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
Hi guys, anyone got problems after make DPF, ADBLUE OFF on this ecus edc17c6o ?
i have tried a few by boot, bench or OBD , tried also correct checksumms by several softwares all original of course;
after a few time all 3 cars i have tried dont start, need to wait some minuts then it starts again;
If i put original file ll is good.
No DTCS, no limp mode, all working good only dont start some times not always, and it as to be something on file .
haythoumazz (31st August, 2020), immokill (22nd September, 2020), itsfun (18th January, 2022), klonone (28th April, 2020), Named25 (9th May, 2020), nicojetski (9th May, 2021), Preslei (24th September, 2020), sonic 1989 (31st October, 2019), VictorBazan (5th February, 2020)
Why do not you put the files here and say we have a solution
no spam in sigs !!!
Here they are.... if anyone can help i will test next car
Pass by pm pls
hi friends
who have good solution to adblue off PSA edc17c60 ? tested solution
and what need intervention in car ? remove pump adbleu or disconnect it ? and another ? maybe reset or .... ?
How did You finally reset the UREA warrning ?
i have citroen c3 picasso 1.6 hdi edc17c69
after remove ad-blue ,programmer bsi (remove denox to list), the car, after 2 week don't start
no error list diagnose
i writhe eeprom back-up , the car restart
after 2 week , don't start
solution?
