Results 1 to 1 of 1
    Sep 2015
    Default Audi Q7 2007 3.0 tdi glow plugs timer maps please
    Hi guys, with problems to start when engine cool. When cold below 15*C starts well, but above 15*C is hard to start.
    Glow plugs fitted new.
    Connected and LED tester to a glow plug cable for testing and the results:
    When engine temperature below 15*C it powers up the glow plugs and starts one kick.
    When engine temperature above 15*C no power sent to glow plugs, and needs to insist to crank for some time to start, but if connect the scan tool and do the glow plugs actuation it starts one kick.
    I need to increase the glow time at temperature range above 15*C on the glow plugs timing maps, but strugling to find the maps.
    Can someone please tell me where is the glow plugs time x temperature Maps.
    This is the Audi Q7 2007 3.0 Tdi BUG engine ECU 4L0910401N EDC16CP34 FLASH Memory S29CDO16G...
    Attached the Flash Dump maps file.
    Many thanks in advance
    PS...
    Forgot to mension, this Maps are from a vehicle originally without DPF, it might be usefull for someone for DPF OFF projects.
