Results 1 to 13 of 13
    Default tuned file FOR RENAULT TRAFIC DCI
    Hello
    I need a good modif tuned file for RENAULT TRAFIC DCI 80CV
    Here original file:
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Chiclana
    I think than you have to modify your file, because if you put a bad file you can lock your ecu.
    If I remember your file have 40kb and is very easy to modify with winols.
    Don?t try to modify with ecm because I don?t find the driver.
    I?ll hope had help.
    Excuse my english is very bad, but I?m spanish.
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by SIMCAR2 View Post
    Hello
    Here original file:
    IF YOU WANT PLAY TUNER,GO BUY FILES,I FIND LOT OF REQUESTS FROM YOU FOR TUNED FILES.
    DO YOU BELIEVE IN FREE TUNING,AND ALL BARGAIN FOR YOU?
    Portugal
    Quote Originally Posted by rsibiza View Post
    That?s right...
    Top Poster andrassh's Avatar
    Where to buy professional files?
    Thx!
    Quote Originally Posted by andrassh View Post
    Thx!
    Maybee from aproved lokal tuner...having some year of experiance and maybee a rolling road.
    Top Poster naruto12's Avatar
    Portugal
    And what is your advice for buying tools and software? I want to start chiptuning, but I have only upa programmer for airbag reset! The orig. MPPS is ok?
    THX!
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    THX!
    If you want to make chip tuning one tool is not sufficient. Minimum that you need is a good programmer, Flasher, BDM Tool, Soldering station.
    THX!
    milanoff is completely right at 100%.
    You need more than just a serial programmer.
    MPPS ori is good tool,does not all engines but lot of them,and not too expensive.
    You would also need BDM but no chinese one....
    And paralel eprom/flash programmer
    solderstation with unsolder clamp,is lot better than hot air,and hot air gun...
    This should be ok,to start with tuning....but does not give you the knowledge you will need to do it.
    I have a Gordak 952 station.. not so good but is ok for starting! Where can i get a good solder station with clamp?
  13. #13
    Good quality is ersa,but not cheap.
    If you wanna start something seriously,i can only say my ersa have now 10 years,works fine as the first,if a ceramic heating pipe breaks,i wait just 2 days get new one.
    Real happy with that tool.
    Vac pump
    solder clamp with al needet clamp points(plcc..flash...)
    solder point
    hot air
