Results 1 to 5 of 5
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    Default Ford icon Dash read 1k78x solved
    i have to read the chip to get immo data to sync to ecu but i can not find the connections for xprog i use the visteon dash connections but only get "Bootloader not found , check Bdm connection" sorry i put the pics in rar file , it is Ford 2006 icon , any help would be nice
    xprog had bad contact on bdm plug and i used this bdm to read dash , works like a charm
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
  2. The Following User Says Thank You to jakesman For This Useful Post:
    amor89 (5th January, 2020)
  3. #2
    Aug 2015
    Spain
    Try this PINOUT. Is the ORANGE 5
  4. The Following User Says Thank You to Josue For This Useful Post:
    jakesman (8th May, 2018)
  5. #3
    jakesman's Avatar
    Oct 2013
    my board is not the same as in picture i used connections from nyo 2006 ford focus vistion dash , when i read the immo light powers up and flashes and xprog give me boot loader error , should i power the dash and then read it ?
  6. #4
    Aug 2015
    Spain
    Try this PINOUT
  7. The Following User Says Thank You to Josue For This Useful Post:
  8. #5
    jakesman's Avatar
    Oct 2013
    just a question ? i got a new ecu sim210 brand new , old one is burned , so i want to make syncro , i took eeprom 93c86 from the old ecu and put it in new ecu , immo light is flashing , but with old ecu it was starting but only some sensors was not working on the ecu thats why i swaped ecu , but now when i put eeprom back to old ecu i also get immo light flashing , so why
    i used this connections , must i give power to dash also
  9. The Following User Says Thank You to jakesman For This Useful Post:
    hmagga (4th August, 2022)
