Results 1 to 10 of 10
    Oct 2012
    Default zafira b 1.9 dt dpf off
    hi all,need help to remove dpf+p1902 from opel zafira 2006 1.9dt
    BOSCH EDC16C9
    0281012549
    1037377267
    I tried it myself,but no you.
    tnx in advance!
    johak's Avatar
    here you go
  3. The Following 2 Users Say Thank You to johak For This Useful Post:
    djrjay (18th April, 2020), perovuk (9th May, 2018)
    Oct 2012
    good job,tnx bro!
    Apr 2011
    need help to remove dpf from opel zafira 2006 1.9dt
    BOSCH EDC16C9
    0281012549
    1037377267
    Thank
    mancioks's Avatar
    Feb 2017
    Germany
    Sensors can be disconected.
  7. The Following User Says Thank You to mancioks For This Useful Post:
    INEGMA (7th August, 2018)
  8. #6
    Jan 2012
    DPF + P1902
  9. #7
    Newmotors's Avatar
    May 2019
    brazil
    test is dump file
    thanks + reported
    PASS IN PM
  10. The Following User Says Thank You to Newmotors For This Useful Post:
    djrjay (20th April, 2020)
  11. #8
    Jan 2012
    its not good.
    DTC still here and car immediately in LIMP mode.
    Only to 1200rpm.
    When i make DPF off nad DTC off with Swiftec, so its ok but after 30sec car is in LIMP mode and rpm only to 2200.
    Problem is the DPF exhaust temperature sensor (p1901-1902).
  12. #9
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by djrjay View Post
    its not good.
    Only to 1200rpm.
    here you go mate test and report
    pass in pm
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  13. The Following User Says Thank You to chrisimerk For This Useful Post:
  14. #10
    Jan 2012
    so finally its not good.
    when warm up then LIMP mode again
