    Feb 2017
    Default corsa DPF off please
    Hi mates,
    I have 2009 opel cosa z13dtj with ecu MJD603.S7.The customer had the DPF opened and empty then he had these fault codes(please check the picture).My question is that if i make the DPF off would it solve the problem?If yes then please i need you help with DPF off file.I used galletto to read file by OBD2.
    Thanks in advance,Regards.
    Usa
    try this and report
    renew before writing
  3. The Following User Says Thank You to quikcar For This Useful Post:
    ecu repair (10th May, 2018)
    Feb 2017
    Thank you mate for your support,i would try it and report it back.
    Feb 2017
    I tried your file and when it start the car i could have gas pedal going to the maximum (before it could not go more than 4000rpm) also the first fault code(gas exhaust temperature sensor is gone but i still have the second fault code(P253F-08 unknown dtc)...I erase it and it keeps coming back after i start the car..Any further help is much appreciated.
    Thanks in advance.
    Usa
    P253F diagnostic code which indicates that the engine oil has deteriorated.
    renew oil in ecu
  7. The Following User Says Thank You to quikcar For This Useful Post:
  8. #6
    pike's Avatar
    Sep 2013
    Hi.
    This can be turned off with several switches in Oil Life Management.
