Results 1 to 15 of 15
    Top Poster + pjtaff's Avatar
    May 2009
    Default alt.dol where do i get it and how to use it
    hi just wondered if anyone could help i am getting a few games on my hd loader that just reset my wii back to the start menu when i try to play them
    have looked about the internet for a solution but still no luck apart from this alt.dol thing so just have a few questions
    1.where do i get it from have tried google but cant seem to find it only a few dead links
    2.if i do get it how do i get to use it
    3.can the same alt.dol file do all the games with this prob or do you need a different one for each game
    also when trying to install new games on the hd through the wii and usb loader gx on a few games it just freezes half way through installing then the system crashes and i get aload of numbers on the screen then i have to turn the wii off at the wall
    many thanks
    taf
    May 2009
    Quote Originally Posted by pjtaff View Post
    many thanks
    taf
    come on people someone must know how its done please share the knowledge and help me and many others out
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    OK here we go....
    .dol files are executables for the Wii. They are essentially the way to start the game.
    Some games, like Mortal Kombat: Armageddon, only display a startup screen and then load another executable, but this breaks the USB hack.
    By choosing an alternative .dol, we are starting the game up immediately from the desired point so that it works as long as it never tries to load another .dol file again (most games don't).
    Some Wii games reload a different executable file at some point throughout the game. This eliminates the hook to the hard drive and the game will crash. To get these games working, you can load the file needed by the game directly instead of loading the normal game. Some of the games that require this are Fate of Atlantis included in Indiana Jones and the Staff of Kings, compilation packs like Metroid Prime Trilogy, Mortal Kombat Armageddon and the MotionPlus tutorial videos found in MotionPlus games (e.g., Wii Sports Resort).
    In the newest loaders there is an option to use alt.dols. In the case of Configuratble USB Loader (which is the best USB Loader IMO)....
    1. Select your game and push 1 to enter the options screen
    2. Go to the "Alternative dol" and select Disc with the D-pad
    3. Press 2 to save options if you like
    4. Press A to start game
    5. Configurable will ask you to "Select alternative .dol"
    6. You need to select a .dol that is not main.dol with the D-pad
    7. Push A when done to play the game
    I cant decribe how to do it on other loaders as I dont use any other for my USB Drive. I use Neogamma only for disk loading.
    XBMC/KODI Developer
    May 2009
    can you have seperate dols for different games in different folders?
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    Quote Originally Posted by ManofScience View Post
    The loader finds the dols for you in the WBFS file. Nothing to download and put in folders.
    XBMC/KODI Developer
    May 2009
    Quote Originally Posted by MetalKettle View Post
    gotcha - so it just looks for the other dol. *penny drops*
    couldn't get SSX to run and saw it needed the alt.dol but never went further than that.
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    gotcha - so there already included in the games?
    Yep the alt dols are included in the games. You only need to download if they need to be patched first, like in the case of NSMB (for some users).
    In Configurable USB loader....
    If you go to the cfg usb settings for that game. Scroll down to the setting that says Alt dol [1found]
    push right until it says ssx.dol (ie. not main.dol)
    run the game
    SSX and Red Steel both work fine this way, but not by using the default main.dol.
    This setting then can be saved on a game by game basis, so you dont have to do it every time you want to play.
    XBMC/KODI Developer
    May 2009
    right still cant seem to sort it out im running my games off a hd and using gx loader
    i tried changing the setting to dol on disc nothing,
    so i tried dol from sd card it just told me i done something wrong and im an idiot well they got that right
    it also says that i need rztp01.dol in the root of the sd card but ive been searching now for hours trying to find this rztp01.dol and no luck any chance you could give me a idiot guide on how to do it and where to get this rztp01.dol from
    many thanks
    taf
    Mar 2008
    To the grave telling it like it is.
    I hope the new Silent Hill isn't a pain in the arse like SSX is, that's the one game I couldn't get working - not bothered about it now though ~~~~ it .....I'll cry if Silent Hill reboots my Wii after I give it the alt.dol, convert to PAL etc etc.
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    many thanks
    taf
    Do any of your games work vis USB? If so which ones reset the wii?
    XBMC/KODI Developer
    May 2009
    most games work fine have to turn the oo2 fix on alot of games but dont really know what all the other setting are for.
    theres a few that crash the wii cant remember all but i know the main one is wii sports resort
    also seem to be getting alot of probs with the hd when i go to usb gx loader i get the hd page up but not showing any games then after a few seconds the screen turns green and the wii crash's and goes back to the start page it keeps doing it then sometimes the games come up and when i am scroling through the games it does the same again turns grenn and crash's
    really doing my head in now
    i do turn it off at the wall when not using the wii will this be doing anything to the hd do you think
    many thanks
    taf
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    many thanks
    taf
    What drive are you using m8. Some drives have a spin down feature which causes them to not play nice with the wii.
    XBMC/KODI Developer
  13. #13
    May 2009
    im using a iomega 1tb drive,
    right i got the sprots resort to work but i am still getting the problem of the drive crashing sometimes its when i am scrolling through the games it will crash or sometimes it wont even load it just crashes all the time
    once i have selected a game then i have never had a prob with it crashing
    also i am going to set up a drive for a m8 of mine for his kids for xmas and really dont want him to have the problems im having, so what is the best drive to use and how much would it be
    many thanks for all your help
    taf
  14. #14
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    Westeren digital are considered to be rock solid on the wii.
    Do you have more than 500 games on the drive? And what loader are you using. Some loaders wont support more than 500 files on a hard drive.
    XBMC/KODI Developer
  15. #15
    May 2009
    got about 200 games on the drive and im using usb gx loader
    also what drive makes do you suggest that works best with the wii
    many thanks
    taf
