Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Jul 2013
    What does that red/black wire do? Do I just cut it after I have turned on the car and everything should just work? Will the steering lock still lock after this when I take out the key?
  2. #17
    Jun 2009
    sweden
    Default j518
    Quote Originally Posted by tusentack View Post
    how did it work,did you cut the wire?
  3. #18
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi mates,
    I have audi a6 with problems. I changed ELV to donor one and I do immo off on ecu but car no start. Maybe original ee from elv is wrong but I dont how check it out. Is there a software or way to do it?
    I saw on this you can check ee and flash from elv.
    Thanks a lot
  4. #19
    Nov 2018
    Poland PL
    post here orginal dump.
    after turning the key in the ignition, does the lock unlock, ignition turns on or no reaction to the key ??
    did you do EZS diagnostics?
    connection to EZS via OBD is?
  5. The Following User Says Thank You to yarowsc For This Useful Post:
    alclot (24th January, 2020)
  6. #20
    alclot's Avatar
    Sep 2009
    Melee Island
    Quote Originally Posted by yarowsc View Post
    Hi mate,
    Elv doesnt unlock after turn ignition on, starter doesnt work with key and only turn on the MMI screen.
    ELV has communication on diag:
    00185 - - elv problem
    00288 - actuartor N360
    00166 - problem on immo
    What do you think where is the problem?
    thanks in advance
  7. #21
    igorr's Avatar
    Aug 2010
    00288 - actuartor N360 motor problem
    cs1
    970C00812E18
    cs2 F2198EFDE433
    mac D3833629
    pin 51906
  8. The Following User Says Thank You to igorr For This Useful Post:
    alclot (25th January, 2020)
  9. #22
    alclot's Avatar
    Sep 2009
    Melee Island
    Quote Originally Posted by igorr View Post
    cs1
    970C00812E18
    cs2 F2198EFDE433
    mac D3833629
    pin 51906
    Hi. Then dump is ok right?
    I will try to change motor.
    Thanks for answer
  10. The Following User Says Thank You to alclot For This Useful Post:
    igorr (25th January, 2020)
  11. #23
    Jun 2017
    Quote Originally Posted by alclot View Post
    Thanks for answer
    I never use this but it seems like a good option https://www.ecudepot.com/product/audi-j518-emulator/
  12. #24
    Member turbo16v's Avatar
    Mar 2018
    Hi guys
    What do I need to repair the EEPROM file from J518
    can someone help me?
    Thanks in advance
    i already have problems with spelling in my mother tongue and google translator is not doing better
