Results 1 to 7 of 7
    Nov 2017
    Romania
    Default Hiunday Tucson 2.0 DPF OFF
    Hey guys! anybody knows a good solution for a Hiunday Tucson, 2.0, 103 kW for DPF to be off ? EDC16C39
    With "Proffesional DPF Remover" i get nothing. Still getting error about DPF, and car does not get out of limp mode.
    Thank you!
    Here is the file i read with Kess. Thanks!
    johak's Avatar
    try...........
  3. The Following User Says Thank You to johak For This Useful Post:
    haidumartocian (16th May, 2018)
    Nov 2017
    Romania
    Quote Originally Posted by johak View Post
    try...........
    Thanks for the quick reply! Did not worked....It seems that car runs better with EGR connector removed, but then i get also error from EGR. Maybe to try an EGR off too ? Particle filter is removed tough....
    ADS's solution will not work.
    johak's Avatar
    dpf and egr
  6. The Following User Says Thank You to johak For This Useful Post:
    Nov 2017
    Romania
    With second solution engine don't stay on more than 2 sec (like immo problem in old VAG group).
  8. #6
    johak's Avatar
    try this.........
  9. The Following User Says Thank You to johak For This Useful Post:
  10. #7
    Nov 2017
    Romania
    try this.........
    ok, this seems to work fine! Thank you!
