Results 1 to 7 of 7
    Mar 2018
    Default laguna 3 error after dpf off
    hi friends,
    i have made a test on my car laguna 3 2dci 130hp
    ecu edc16cp33
    i have made dpf off and egr off,after that i have removed the heather with the tool from my new genius . now dpf and egr are deleted but i have check service error on board and cruise controll doesent work.
    i must say that i doesent removed the cheksum i dont have a tool for this.
    i put here a arhive with the original dump readed and the modified one, if any one can help me with a sugestion what should i do , where i have made the mistake
    johak's Avatar
    try with this file
    tek2dk's Avatar
    Oct 2012
    under the sea
    @rares01 - the engine is runing but is limited? I think u lose the injector code when u write the file. Try to make a diag with clip or x431!
    Mar 2018
    i have saved the injector code and rewrite, i tested with clip no errors found , but in dashbord i have service error , i think it comes from cruisecontroll because it doesent work now
    i will test the software from johak and repost.
    tek2dk's Avatar
    Oct 2012
    under the sea
    With clip try to activate cc/sl in cluster.
    Babos's Avatar
    Mar 2012
    Because it is not complet solution!
    Mar 2018
    i tryed with clip to activate cruise control but it says function unsuportable.
    any sugestions?
