you can try to write with fgtech by obd, if you do this job with Kess, you brick and lock ecu..
Fgtech give you option to write ori back by obd
Regards,
Regards,
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
i have fgtech galletto v54, but i don't have option for to write ori back. I must to write ori with normal write, but this i can to make with kess too. or i am doing wrong?
No do with fgtech, he write till 100% if not ok, you can write ori back fgtech give you instructions
Sedat Garip
Belgium
With Kind Regards,
maybe also kess tell you "ko" at the end of write, if file is not ok
the file is not ori
i have only kess then i can't write this ecu one of you have this file ori?
boys i finded a ktag, but ktag can to unlock tprot for this ecu?
K-tag read & write this ecu without problem.
FGTech read & write boot tricore without problem too. But before write mod file by obd - we should remember !!
NOT CALCULATE CRC ! FGtech will count alone.
mircea13 (17th May, 2018)
I don't understand people like this, its like playing with fire. Why don't you take out ecu from car, open it (which is very easy in this case) and read/write boot with simple clone tool (galletto, ktag etc) then after all you sleep fine. This procedure takes less time than starting this thread on DK
Ok boys, i I wanted to know this. then I can do everything with ktag without problems in tricore. so I do not have to do anything for antituning?
