Results 1 to 10 of 10
    Aug 2016
    Default China psa remote 7941 possible unlock?
    I buy several psa china remote but all is locket. It is possible unlock with vvdi2 or vvdi key tool?
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    I can't understand what do you want. You want to virginize 'em what makes you to be able to use a 206 1C remote with precoding for every pug remote with the same outfit, or you want to be able to put the remote into a cloner?
    P&D's Avatar
    If your reading the remotes with a zedbull clone the machine will say there locked when there not
    read them in Hitag to see if there locked
    And the answer to resetting them is yes if you have the correct tools & files for the chips
  4. The Following User Says Thank You to P&D For This Useful Post:
    MaxMin (17th May, 2018)
    Aug 2016
    First i read with vvdi2 and not possible read remote page and other page,i try with effi and zedbul and is same,not possible read remote page,i try programming in car (p407) and always fail, and i start car with simple pcf7936.
    P&D wich tool can unlock this 7941?
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    VVDI Key tool has such kind of expansions what you are looking for
    P&D's Avatar
    They sound like there locked or dead chips on them
    can you read the IDE serial number ?
    http://www.vvdishop.com/upload/pro/x...ng-diagram.pdf
  8. The Following User Says Thank You to P&D For This Useful Post:
  9. #7
    Aug 2016
    I not have vvdiprog,only vvdi key tool and vvdi2, in manual vvdi key tool have for original psa key,im not sure it is file from vvdikey tool compatibile for china remote.
  10. #8
    Oct 2015
    Quote Originally Posted by MaxMin View Post
    just try and you will know
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  11. #9
    castin's Avatar
    Oct 2015
    China PCF7941 hawe problem with firmware inside. You can unlock this remote (PCFPROG or other), but remote function not work - remote don't send ASK/FSK signal.I think its low qty pcf7941 chip.
  12. The Following User Says Thank You to castin For This Useful Post:
    MaxMin (18th May, 2018)
  13. #10
    Aug 2016
    Thank you,vvdi key tool not have in menu psa remote for renew.
