n599fbm (31st December, 2013)
hi
need your help to kill im*o in this ECU
car: fiat uno 1.3 8v
ECU :IAW 4AFB.UA
eprom : 95160 ( dump attached )
the problem is im*o box fired , get other one but its with MCU motorolla 1K59H unreadable !!
have also original keys red and blue and also original pin from dealer
any help will be appreciated : adapt , im*o off ....
thanks.
@adusia123
thanks but this file is generated by otocheck immocleaner2 is not ok for 2 reasons
1 its for fiat marea 16 v mine is 8V
2 its repair file = recode
tested and car not start without and with immo box ....
so any other tested file ?
so now its clear ( if IAW4AFB.UA = IAW4AF M...or S )
1st solution is to have a valid key with im*o box (that isnt my case: key and ecu are from same car but im*o is from another !!)
2nd solution is to feet emulator to this ecu ( i have not schemas and dump !!)
3rd solution is to make key from im*o box dump (i have zedbull to do that but mask motorolla is 1K59H, i cant read with UPA and OMEGA !!)
My friend, try this file and read here (I'm sorry but is in italian):
Sulle vetture che hanno il body computers devi recidere il pin 29 e 20 colore rosa e rosa/nero, in questo caso la vettura parte senza code ma come difetto non funziona ne contagiri ne temperatura acqua., se non vengono tagliati questi fili parte sempre vergine anche con il file totale
DOUGLASMAITA (6th September, 2016), ecufix (30th October, 2019), n599fbm (31st December, 2013), PierreTheron (9th April, 2019)
I have seicento 1.1 8v Mpi IAV 4AF and I need dump no im*o
please help me
thanks a lot
