Page 1 of 6 123456 LastLast
Results 1 to 15 of 86
    DK Veteran kasim_izmir's Avatar
    turkey / izmir
    Default FORD IDS MODULE PROGRAMMING
    Hi to all , please can you make help to me about IDS
    I buy vcm-ids with V63 dvd , i install working good. But , module programming menu empty . I use ids with V59 before all is OK.
    How , i will turn back from V63 to V59
    Thanks to all
    kasim
    Essex
    i think you will find fords have done this to mess up cloned vcm modules . u will need to try totally uninstalling newer vertion and reinstalling the older vertion , if not load older vertion to another pc , also the vcm might be imprinted with the newer vertion . i run only latest vertion and i have to go online to get permission to install new modules now .
    not good i know but this is the way fords have gone now.
    HTH
    turkey / izmir
    Quote Originally Posted by squirrelbandy View Post
    HTH
    I try to install V59 another computer , But not success
    Because , i think writing Version info to VCM module
    problem is same , give me testman error
    Kasım bey ıds de bende problem yaşıyorum mod?l programlama ?ıkmıyor yardımcı olabilirmisin
    Staffs UK
    you could try flashing the head over to Jag/LR and then back to V59
    turkey / izmir
    Quote Originally Posted by nutloose View Post
    OK friend , thx ... I will try
    Top Poster Digital Auto's's Avatar
    Hi, did you get anywhere with this, I've the same problem..
    Ive the same issue, anyone got a solution
    North West
    +your probably going to dismiss this -
    but just get a xp pro install disk - make a complete new fresh install of xp pro. do not connect to the internet, once finished, but make sure you have sp 3 install disk -
    put the date to 2000 during install
    run the ids ford v63,
    plug in vcm cable - sort local area connection realtek 1850 so its installed -
    plug into vehicle and your programming will be fine.
    ONCE YOUR PROGRAMMING IS GONE DOWN ON THE LAPTOP YOU USE IT IS IMPOSSIBLE TO BRING IT BACK WITHOUT THIS METHOD>
    the suggestion of flashing with Jaguar is a good one to remove any previous ford flaSH, BUT WE ARE convinced that no dates are stored in there. While it may remove any potential information ford want stored there, one thing is for sure and that is that this will not bring back programming to your exisiting installation of ids and xp pro. IT MUST BE WIPED
    I would not go rushing into V65 just yet, worth waiting a little longer to see if the rumours of problems are true.
    Oh and make sure you V63 install is the full install with caliberation files.
    using the ford inhouse - vcm clean or any version of the IDS clean up sopftware will not bring back programming even if you reinstall ids..... it will not work
    cleaning the registry is a waste of time - you wont clean it , even fords own clean up software leaves traces inside the registry
    JUST TAKE 60 minutes out - do the clean install, with date amendments, it wont run out, time out or similar.
    WOW REALLY...ITS NOT ALL THAT HARD READ ITS HERE...GESSS
    My friend for activate the module programming you need only unistall the IDS after that change the Date of you pc and the BIOS for the date when liberate the version 63 and make a new install. after that try entry to proramming module and works.
    The problem is because when you update the IDS software have only 3 months after release date for make a install or module programming is disable.
    Good luck
    Is very important clean the registry you can use ccleaner
    foxtec800's Avatar
    search dk for ids activation workaround and you`ll find the best solution , if you do it right you can use up to v65 on china clone,, no probs ,, it runs all ids files in may 09 date window everytime ids starts, gets over 3 mth update rule
  13. #13
    Czech Republic
    Default Module programming period extension
    Hi all,
    I found solution how to solve problem with disabled module programming after some time. This procedure was tested only with v57.
    First locate c:\Program Files\Ford Motor Company\IDS\Runtime\Apps\mcp.ini
    At the end file is line with MCP_VERSION_TIMEOUT=255
    Change this to MCP_VERSION_TIMEOUT=1000
    If your version is expired there exist file
    c:\Documents and Settings\All Users\Application Data\Ford Motor Company\IDS\Users\_to_flag.exml
    Delete this file and run IDS. Module programming should be available again.
    v65 solution
    Replace c:\Program Files\Ford Motor Company\IDS\XMLFiles\71863.tml with attached file.
    Delete c:\Documents and Settings\All Users\Application Data\Ford Motor Company\IDS\Users\_to_flag.exml
    Time period extended from 120 to 1000 days.
    Last edited by xbobcz; 7th August, 2010 at 11:11 AM. Reason: Another version of IDS added
  14. The Following User Says Thank You to xbobcz For This Useful Post:
    estwood68 (30th March, 2017)
  15. #14
    Aug 2010
    Hi I have v63 and i am looking for a solution to this without formating the drive as i also have pp2000 and lexia on the same partition. Has anyone found the same kind of solution as in the previous post but for v63.
    Thanks Alan.
  16. #15
    Quote Originally Posted by foxtec800 View Post
    theres a v65 work around here but it has bad trojan i it dont use it. just take back the pc date to any verion go find out the dte it was releaded and go to that date and keep it there and your fine or just flash a car every month then your fine to. i flash cars that dont need it or arent there fo rthat just to keep it open. one a month is all it takes ot do it.
