Results 1 to 10 of 10
    Feb 2014
    Default Key program Renault Scala 2012
    Hello friends, I need to program two new keys in Renault Scala 2012, I have work in this car with LAUNCH. Fistly I was tried to entry as Renault brand, but dont connection. In the second chance i tried as Nissan and the communication is well, even it shows me the VIN of the car. In anti theft it says uses NATS 5.0, this system is of NISSAN. When I connected with SBB I try with Nissan Almera Tino 2001-2004 and apparently I was connected, but the PIN is needed to program key, and I have not the PIN CODE. I was try to read PIN CODE by means of Option in SBB NISSAN BCM PIN CODE, but not connection. I have understand the BCM in this car is forming part of Dash board. I need to know how to get PIN CODE with VIN, and if I can to try with SBB even when for Almera Tino the key used is 4D, and Scala uses ID46. I have the two new keys in my hands, and i have another doubt, the news keys says when i readed with Zed Bull Mode Locked.
    newone's Avatar
    Oct 2016
    if it is nats5 post antenna sticker or bcm sticker to get pin
  3. The Following User Says Thank You to newone For This Useful Post:
    davidobd2 (21st May, 2018)
    Feb 2014
    BCM in this car is in DASH. I need to review that.
    Enviado desde mi E5306 mediante Tapatalk
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    It is a Sunny, not an Almera...
    From other side it means that you can read the pin via OBD
  6. The Following User Says Thank You to PocketHero For This Useful Post:
  7. #5
    Feb 2014
    I need to know if the code of six digits from BCM is in the case of this car in dash
  8. #6
    Feb 2014
    I triee to read pun from BCM NISSAN in SBB but not work
  9. #7
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Sbb is a bit overaged... Try a new one ;-)
  10. The Following User Says Thank You to PocketHero For This Useful Post:
  11. #8
    Feb 2014
    For example. Please says me some tool not much expensive at least for this renault
  12. #9
    Feb 2014
    Or for clone ID46
  13. #10
    newone's Avatar
    Oct 2016
    Quote Originally Posted by davidobd2 View Post
    Or for clone ID46
    vvdi key tool
