you need block EGR
Hyundai Santa Fe CM 2008 Economy Tuning or stage 1 needed !
1037384597
0281013584
P.S. with that dpf+egr off values are ok with sensor connected , egr valve 4.8% all the time , dpf presure 0 ps , dpf sensor temp 127 grade celcius
But before the car not has power even with full acceleration , and many smoke on exhaust , so DPF was fully blocked
After i remove dpf physically , now i have few black smoke but loss power from ----2000RPM ,and after 2000RPM is ok.
you need block EGR
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
I blocked egr but same problem again ! Many smoke on exhaust and not power from 700-2000 rpm.
Problem solved ! Injectors code does not belong my car
