I need clear Twingo 3 985100858R
SPC560
SPC560
Your cleared file, clear errors, switch ign off for 15 sec, switch ign on, clear errors again and report ...
Scripts for Multi-PROG
Best regards.
Dragon
File not work
Which errors ?
Best regards.
Dragon
Fault ECU (internal error)
I have fault DF194 Replace ECU SRS
Please help
Check this, tested file 100% from other car, I did change vin like in your file ...
Best regards.
Dragon
alexline (9th July, 2018)
Hi, I can ask you if you can have the password for this file?
Thanks it's work
