Results 1 to 15 of 18
    Mar 2011
    EU
    Default MERIVA 1.3 CDTi problem
    I have a problem with meriva 1.3 CDTi mjd ecu, DPF off was made by someone, but glow light is blinking all the time, and car smoke lot when starting.
    I doesn't have the ori file.
    If someone can look at this file.
    CHEERS
    pike's Avatar
    Sep 2013
    Hi, read flash file.
  3. The Following 2 Users Say Thank You to pike For This Useful Post:
    kinketotua (27th May, 2018), Ocin (24th May, 2018)
    Mar 2011
    EU
    Flash attached
    3inferno3's Avatar
    Nov 2014
    Europe
    can u write details of ecu? number...
    Mar 2011
    EU
    55574587 RP
    HW 012460204D
    SW 0001
    Z13DTJ
    Mar 2011
    EU
    Someone can help me ?
    pike's Avatar
    Sep 2013
    Try to test engine with original file.
  9. The Following 2 Users Say Thank You to pike For This Useful Post:
    kinketotua (27th May, 2018), Ocin (26th May, 2018)
  10. #8
    Mar 2011
    EU
    I don't have ori file ...
  11. #9
    mancioks's Avatar
    Feb 2017
    Germany
    Can use this to restore changes were done before in your file.
    Spare: 55574587 RP
  12. The Following 2 Users Say Thank You to mancioks For This Useful Post:
    Ocin (26th May, 2018), VWLT (28th May, 2018)
  13. #10
    pike's Avatar
    Sep 2013
    Arrow MERIVA 1.3 CDTi DPF off
    Quote Originally Posted by Ocin View Post
    55574587 RP
    HW 012460204D
    SW 0001
    Z13DTJ
    here correct DPF off solution.
  14. The Following 4 Users Say Thank You to pike For This Useful Post:
    kinketotua (27th May, 2018), konq100 (24th July, 2018), Ocin (27th May, 2018), VWLT (28th May, 2018)
  15. #11
    Mar 2011
    EU
    your file work fine ! thank you m8 !
  16. The Following User Says Thank You to Ocin For This Useful Post:
    pike (2nd June, 2018)
  17. #12
    pike's Avatar
    Sep 2013
    Welcome...
  18. The Following User Says Thank You to pike For This Useful Post:
    Ocin (5th June, 2018)
  19. #13
    Heloo
    Someone can help me with a original file for:
    Opel HW : 55574587 RP
    Marelli HW : MAG 01246O2M06005
    Marelli SW : M06005
    Engine code : Z13DTJ
    TKS
  20. #14
    pike's Avatar
    Sep 2013
    SW: 3422M167 ?
  21. #15
    Jan 2013
    Inside ECU
    Use tech2 or mdi do spsl
  22. The Following User Says Thank You to leotdx For This Useful Post:
    cuiuda (18th January, 2019)
