Results 1 to 2 of 2
Hybrid View
    May 2018
    Default RCD 500 car radio code
    Hi, bought a used RCD 500 Blaupunkt car radio on Allegro and did not realize it was without code. Should I return it to the seller or is it possible to get the code somehow.
    Have the original player of the same type which I removed from the car due to the fact it was draining power from the battery when the ignition was turned off.
    Thank you very much for your suggestions... regards
    Sep 2012
    read 95640 post dump for code ..
