hello guys i have problem with one alfa 147 1.9 jtdm 150 hp
the car have dpf ,and dpf has been blocked 98% and is removed mechanical and sensor unpluged,after that the car is flying from the power and working very good
after 2 hours drive car is coming to me to make dpf off in limp mode car won't passed 2000rpm and check engine light
i flashed the dpf mod file and egr off too,
the car is very slow in low rpm from 1000 to 3000rpm ,when is passed 3200rpm the car have big power and working good
the sensor dpf pressure is pluged and is 27mbar and egr is pluged too when car pass 2000rpm and work good after 3200rpm
if i unplug dpf pressure sensor is 1250mbar and egr unpluged the car won't get 2000rpm
what can be problem can someone help me
the file is obd read by galletto
dtc are
P1206
P2455
P2452
P2085
