Can anybody please help with the configuration data on a 2010 Qashqai J10 remote key please
Love this forum
1. SIT IN CAR WITH DOORS AND WINDOWS CLOSED.
2. LOCK DOORS WITH POWER DOOR LOCK SWITCH ON DRIVER’S DOOR.
3. PUT IN AND PULL OUT KEY FROM IGNITION APPROX. 8 TIMES OR UNTIL YOU SEE THE HAZARD/TURN SIGNAL LIGHTS FLASH.(older models lights may flash after 4 or 5 times) YOU NEED TO DO THAT IN LESS THEN 10 SEC
4. WHEN HAZARD LIGHTS FLASH (ON 2005 AND NEWER MODELS THE GAUGE NEEDLES MAY JUMP A LITTLE INSTEAD) , PUT KEY IN IGNITION AND TURN TO THE ACC POSITION.(when your hazard lights flash your car is sending a signal to be received by the remote)
5. PRESS LOCK BUTTON ON THE NEW REMOTE, LIGHTS SHOULD FLASH AGAIN.
IF YOU HAVE 2 REMOTES, 1 NEW AND 1 OLD OR 2 NEW ONES, PLEASE CONTINUE WITH STEPS 6 AND 7. IF NOT, SKIP TO END.
6. PRESS UNLOCK BUTTON ON DRIVER’S DOOR, THEN LOCK BUTTON ON DRIVERS DOOR, LIGHTS WILL AGAIN FLASH
7. PRESS LOCK BUTTON ON 2ND NEW OR OLD REMOTE. LIGHTS AGAIN WILL FLASH.
YOU ARE DONE. EXIT VEHICLE AND TRY YOUR REMOTE. IT WILL NOT WORK FROM INSIDE CAR OR WITH KEY IN IGNITION.
Note: if your hazard lights flash after inserting your key in and out, but you can’t get the remote to program, you may have a dead battery or the wrong remote. If instructions do not work, do it again but when you get in – shut the door, buckle seat belt and lock doors, then proceed to putting key in ignition
daniersms (26th May, 2018), the_riddler (12th October, 2019)
Ok this is for the remote programming what I am looking for is the data on the pages .. see photo which is what I have but it is not working
Love this forum
daniersms (27th May, 2018)
This is new aftermarket key or original used?
Sorry I thought it was keyless type
This is a new aftermarket
Love this forum
He wrote is not working.
If you have effi+zedbul try to precode with effi, it should work.
I tried to sniff data out with id46 cloner but wont give me the config data
Sent from my SM-G930F using Tapatalk
Hit like and thanks if I've helped you!!
Are you sure you are using the correct pincode? Try both old and new
Sent from my Pixel 3 using Tapatalk
