your mod file
Jashmine1983 (27th May, 2018)
lambda off? how you wait to drive without afr monitoring
DSG TUNING
File Service
I've swaped ECU because I got watter in mine...I've cloned It in another EDC16U34 (by BDM) but with this ECU I have seensors ERROR. The ECU motherboard seems the same but is from a BKD engine that has no DPF.That is why I need and lambda error off. Can be done or I need the same ecu code from mine?
Not all EDC16U34 are interchangeable?
of course it is possible to lambda off and use MAP/MAF smoke AFR monitoring - you can see switch in your file adress 1D6F19 - Auswahl Rauchbegrenzung über Lambda (0) oder Menge (1) (Selection of smoke limitation via lambda (0) or quantity (1)) which is set to smoke MAF/MAP(which is determined by another switch after) by default in your ecu so all you need is DTC off....post here your DTC code and I will remove it
Jashmine1983 (3rd June, 2018)
Thanks to all!
Problem solved with another ECU from BMP engin e with DPF....clonned mine with BDM
I've atached BDM files....from BMP and BKD if somebody will need
