remove dtc for ALFA ROMEO MITO 1.4 Magneti Marelli 8GMF.A3
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Jul 2010
    Default remove dtc for ALFA ROMEO MITO 1.4 Magneti Marelli 8GMF.A3
    hi please can you remove a dtc p1300-55 for ecu ALFA ROMEO MITO 1.4 Magneti Marelli 8GMF.A3?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    post your file
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Jul 2010
    Quote Originally Posted by Ignasvw View Post
    post your file
    when my client bring me his car
    Jul 2010
    post your file
    i need remove all dtc P1320 P1300 P1850 P1851
    Attached dump mpc
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    , dtc off
  6. The Following User Says Thank You to Ignasvw For This Useful Post:
    taxi300 (2nd June, 2018)
  7. #6
    Jul 2010
    checksum is corrected?
  8. #7
    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Punto 1.4 8GMF dtc off
    Hello mates ,
    I have the exact same ecu 8GMF on a Punto Evo 1.4 and i need DTC off on the P0512 fault .
    Is it possible on my file too please?
    Thanks in advance
  9. #8
    jurebv's Avatar
    Dec 2017
    Croatia
    never done it but should work
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  10. #9
    Nov 2008
    Thanks for the file friend
    But i programmed it ,, and now Start Stop function not work anymore ,,,
    In Live data ,, check engine light value is Flashing . But on dash the check is off. Maybe that's why start stop not work ?
  11. #10
    jurebv's Avatar
    Dec 2017
    Croatia
    try this file
  12. #11
    Nov 2008
    Not work friend ,,
    DTC pops up again and i get DTC U3FFFFFF now .......... for some reason dtc comes up now but not as P0512 ....
    I think solution not good
  13. #12
    Nov 2008
    Willing to pay for the solution
  14. #13
    Sep 2009
    Maybe a little late, P1300 is not an error but it means Phonic wheel relearn. It is a sync between camshaft and crankshaft.
    This should be done every time after the battery has been disconnected or the trouble codes are erased.
    Warm car up, wait until cooling fans have run twice
    Depress throttle 3 times until engine is at about 6000 rpm
    When decelerating keep the engine rpm above 1200 rpm
    Sometimes you have to execute this procedure a second or third time.
  15. #14
    Nov 2008
    Mate it's not P1300 it's P0512 (:
    As for the phonic wheel relearn ,,, every time i program a file on the car it for sure needs this and i perform it! It's been crazy revving up this Punto all day yesterday
  16. #15
    Sep 2009
    Quote Originally Posted by taxi300 View Post
    I_shot_the_sheriff, I still read P1300 in that first post.
    I replied on that first post. I don't care about others with other problems who high-jacked the topic.
  17. The Following 2 Users Say Thank You to oldford For This Useful Post:
    bobolin4o (15th March, 2019), fluke9 (25th November, 2020)
