Results 1 to 5 of 5
    Default benz w211 e280 dpf egr off
    hello to experts
    benz w211, 3000cc ,v6, e280, 642920engine type
    i need to do dpf off and egr off...
    can i do it by obd with kess?
    is it safe the writing?
    i read the file with kess but didnt do anything because first time
    i work with these cars....*w211 cars*
    need to do anything else???
    thanks a lot in advance
    sw 1037393822
    spare CR4-642-42P7-211WSM-140kW-PT2R05-LR-3907x064ME
    Nov 2018
    looking for the original w211 sw 1037393822
    ivanmihov's Avatar
    Nov 2016
    Europe
    you can write it back with kess,no problem just disconnect cooling fan plug,or use good battery charger
    Nov 2018
    Quote Originally Posted by ivanmihov View Post
    в этой прошивке затерты ошибки. У автомобиля есть проблема- при полном газу уходит в аварию и до 3000 оборотов. При диагностике star diagnosis ошибок нет(( Вот я и ищу оригинальную прошивку что бы понять что не исправно. Если кто может помочь,то поправьте эту прошивку.
    Nov 2018
    Errors are erased in this firmware. The car has a problem - when full throttle goes into an accident and up to 3000 rpm. When diagnosing star diagnosis, there are no errors ((So I'm looking for the original firmware to understand what is not working. If anyone can help, then fix this firmware.
