Results 1 to 12 of 12
    sasy90's Avatar
    Italy
    Default Golf5 2,0tdi Hotstart fix problem
    Hi to all ,
    i've mod file ori of Golf 5 2,0Tdi 103kw with EDC16U34.
    When I mod the file the car works ok, but after one day the car return with the same problem.
    Someone can help me ? The mod is correct?
    Thanks in advance
    File is read with NewGenius Dimsport.
    jurebv's Avatar
    Dec 2017
    Croatia
    hotfix is correct...maybe its not starter motor's fault
    nizarben's Avatar
    Dec 2013
    Quote Originally Posted by sasy90 View Post
    Hi to all ,
    Thanks in advance
    hello
    try this
    WinOLS (VW Golf (hot starfix) - 392942).rar
    Apr 2016
    try to detach the bulb of the water temperature, so doing the control unit will have a fixed value of -40 °, and will increase the ignition time of the glow plugs. if the car starts well, you have to put the glow plug preheating module, because it's not always a problem of increasing the injectors
    sasy90's Avatar
    Italy
    I try to detach the bulb of the water temperature now... and i have the same problem... when the car is "hot", motore makes extra turns and then run....
    May 2018
    maybe do you have G83 temp sensor fault?
    Apr 2016
    changes the engine speed sensor and the camshaft sensor
    sasy90's Avatar
    Italy
    i think that the problem is camshaft sensor... when customers give me car i try to replace it... Thanks in advance
    sasy90's Avatar
    Italy
    Quote Originally Posted by kazsolt01 View Post
    I don't think that.... when i disconnect it temperature go down and in diag i read correct temperature...
    nizarben's Avatar
    Dec 2013
    did you try my file?
    Apr 2016
    yes I had not seen edc16u34, only applies to edc15
    sasy90's Avatar
    Italy
    Quote Originally Posted by nizarben View Post
    mate the customer need car... return car to me in this days... when return i try your file....
