Results 1 to 15 of 23
    May 2018
    Unhappy Digiprog mercedes w212 help !
    Hi, im trying to use digiprog3 on w212 (2010). but it wont read the real data from tacho or EZS. it reads : "OLD :1948032 km"
    and if i type in new km 250 000. it shows :"check written value 1995776"
    and it does not change anything on my cars tacho.
    digiprog is v4.94
    any suggetions?
    Thanks!
    Cllau's Avatar
    Mar 2017
    where friends need me
    ORI will do this no prb, are you trying with a clone?
    May 2018
    Yes its a clone. but it did the job last time, for the same kind of MB w212. This is the same year and black and white display.
    I just cant figure it out, why it reads such a big number of km ?
    Cllau's Avatar
    Mar 2017
    ....maybe the car has a blocker installed....
    Dec 2017
    Drive the car up to 16 Miles then try again but make sure the car is started
    I mean programme while Engine is running
    May 2018
    Did that. no result. Same. it reads about 2 million km. and cant change.... damn
    Cllau's Avatar
    Mar 2017
    step away from that car m8 will give trouble....
    antenor's Avatar
    Here
    Digiprog put 1600000 on EZS. You need another tool to do EZS km.
    If i help, d'not forget to press thank button!!
  9. The Following User Says Thank You to antenor For This Useful Post:
    Kocta (1st June, 2018)
  10. #9
    Nicolas9's Avatar
    Feb 2017
    Aruba
    use better tool. or install canfilter.
  11. #10
    Dec 2017
    Default Digiprog mercedes w212 help !
    Well you don’t need can blocker to programme till 2013
    Basically you need another tool to programme this
  12. The Following User Says Thank You to Happy786786 For This Useful Post:
    cristyand (18th June, 2019)
  13. #11
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Happy786786 View Post
    That's what I said...
  14. The Following User Says Thank You to Nicolas9 For This Useful Post:
    MileageAudit5 (28th October, 2022)
  15. #12
    May 2018
    Thanks guys. yesterday one friend came by and tryed with OBDstar x300m and the same result.
    He tgought that it needed to take tachometer apart, and to the direct programming to chip.
    is there anywhere DIY instructions?
    Thanks for all the info.
    Will give you update how it goes
  16. #13
    letalcrudo's Avatar
    Nov 2015
    Canada
    Quote Originally Posted by crspotest View Post
    just leave that car goes on man. DP3 doesn´t work on that model properly. cheers
  17. #14
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Why keep trying cheap China tools? Use a real good tool. Or program eeprom and use canfilter!!!1! Problem solved
  18. The Following User Says Thank You to Nicolas9 For This Useful Post:
    kachimbi (26th January, 2019)
  19. #15
    uk
    its due to software versions being different for this car.
