Results 1 to 8 of 8
    Jul 2016
    Lebanon
    Default radio says one hour mode
    hi mates any ideas on this type of problem 2011 ford fiesta radio displays one hour mode
    Apr 2011
    Sounds like Ign+ isn't there.
    Try turning on ignition and push and hold key firmly into the lock then turn radio on while doing this.
    See if that helps?
    Mar 2016
    Argentina
    Hello Skilion 290, see if on the radio, in the power connector, have false contact in the rear connector, it usually happens to the radios FORD VISTEON, appears on the display 1 hour for lack of ignition or accessory + 12v, if it is your radio, will have to disarm it completely to be able to resolve the mentioned connector, good luck ...
    richiebb's Avatar
    Aug 2015
    Argentina
    Quote Originally Posted by skilion290 View Post
    check sync module
    Jul 2016
    Lebanon
    hi julesd car starts perfectly telling me that ignition is there pefectly thanks
    Jul 2016
    Lebanon
    hi richie can you please help with the location of this module thanx
    richiebb's Avatar
    Aug 2015
    Argentina
    up and back of the glove box
  8. The Following User Says Thank You to richiebb For This Useful Post:
    skilion290 (2nd June, 2018)
  9. #8
    Mar 2016
    Argentina
    I'm following the failure of the mode one hour, maybe the problem is located in the key drum of the vehicle, since I happened once in a Ford Fiesta, which did not work in ACC mode, the test to determine if the drum is failing is turn on the radio, put the keys in a drum, turn it to the contact mode, and then remove the keys, if in this simple operation the equipment is not turned off, the problem came from there, apart, it can be noticed that the key of the Drum enters very easily, without unlocking the internal mechanisms, luck ....
