Results 1 to 4 of 4
    May 2018
    Default Subaru Legacy 2017 Airbag
    HI i just purchased Carprog and it arrived but does not have the update for modual serial # 98221AL06A on a 2017 subaru legacy. can someone please help me?
    Thank you
    slick_dick's Avatar
    Essex
    post your dump!!!
    May 2018
    I don't have a dump to post because when i search carprog for my module it's not listed and help sends me to the website to purchase 2018 airbag update. i don't know what cable to use or what chip to connect it to so i cant read the chip. i do have a list of fault codes my code reader gives.
    009871, B1650, 09877, B1836, 009652, 009876, 009656, B1826, 009870, B1820, 009692, B1622, B1632, B1901, B1831, B1821
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    Damn, and I thought I had it bad buying carprog in a 2014 before they started releasing new modules in packs that require purchasing.
    But to just buy carprog and it did not already come with it is crazy. I would get ahold of Lina on Skype and ask why it does not come with latest clear solutions.
    If you have AL01A listed, use that. It will display your correct part number when you read it and clear is the same.
    If you do not have AL01A listed in your soft then goto EEPROM software and manually select 95128, use A6 cable and read/verify and post dump
  5. The Following User Says Thank You to repairmymodule For This Useful Post:
    borshch (21st June, 2018)
