Results 1 to 6 of 6
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    Smile Recode Immo for Vauxhall/Opel Using OP-COM
    Got a mates car here,
    Astra G 1998
    basically had a engine replacement, was a 1.6 petrol, now 1.4 petrol (well the engine code comes up as x14xe)
    He has car pass for the immo, vin numbers match but cant code keys to the immo.
    I scanned Immo and it has correct VIN
    I scanned Engine it has different VIN (possibly from donor car)
    Is there anyway i can recode the modules 2 work with each other using opcom???
    Thankyou
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    Yes, you can.
    1. You need to know PIN code of car and use OP-COM
    2. Enter Body>Immobiliser II>Special Function>Reset Immobiliser.
    3. Turn Ignition Off/On
    4. Enter Body>Immobiliser II>Programming>Immobiliser Function>Immobiliser Installed>OK>Yes
    5. Turn Ignition Off/On
    6. Reprogram keys and you are done.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    z786's Avatar
    Aug 2009
    What about coding diesel pump, on some astra/vectra when u replace the pump, you also have to change pump ecu????
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    I. On Vectra C only (Y20DTH an Y22DTR - PSG16 pumps):
    You need to know both pin codes (of car and pump).
    1. ECU > Special Function > RESET ECU (enter Pin -from pump) > OK (ecu is now reset)
    2. Ignition off/on
    3. CIM > Programing > Programing (enter pin code - of car) > Immobiliser Function > ECU installed > OK.
    4. Ignition off/on
    5. Start the car (in this case you don't need to recode keys)
    On Astra G only (Y20DTH an Y22DTR - PSG16 pumps):
    Like in my 1st post.
  5. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
    carfilesolution (1st March, 2024), Lexas (22nd July, 2015)
  6. #5
    z786's Avatar
    Aug 2009
    When you say pincode of the pump, is that the car pass?
    basically you need the pin from the pump the car came from and also the pin for the car you are using in?
    thanx
  7. #6
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    Yes mate. That's the ideea
