Page 7 of 8 FirstFirst ... 2345678 LastLast
Results 91 to 105 of 110
  1. #91
    foxtec800's Avatar
    Anyone used the new JLR duplicate keys function yet ? Is it working
  2. #92
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by foxtec800 View Post
    Tried this function on my discovery sport. Worked perfectly with a xhorse smart key. Even the emergency start worked when I removed battery from fob and placed on bottom of the steering column. Original key was unlocked and KVM is FK72-19H440-AD.
    Sent from my Pixel 5 using Tapatalk
  3. The Following 7 Users Say Thank You to smokey08 For This Useful Post:
    foxtec800 (20th October, 2021), keysmith (20th September, 2021), lion0304 (19th September, 2021), Matronix (19th September, 2021), PremierD (19th September, 2021), u.s (20th September, 2021), Weasel3 (19th September, 2021)
  4. #93
    Jun 2017
    Hi, I buy this programmer some time ago because videos showing that this device is worth of money. Now I have tested programmer and I have to say that this programmer need to urgent update. example Reading DME(MSD81) ISN, shows allways same ISN number. I can’t syncro DME-CAS at all. In programmer software option DME-CAS sync failed every time. Is there anuone who got this programmer working????
    Sent from my iPad using Tapatalk
  5. #94
    Jun 2017
    Quote Originally Posted by spiridonas View Post
    Hi guys i need this tool only for read write isn in ecu ( MSD80/MSD81 mini ME17.2.1 MEV17.2.2)
    and cas3+ module for bmw E series, it is reliable tool for this job ?
    Many thanks in advance
    Acdp mini not good programmer for that. You could read DME ISN but allways show same ISN number. I have never managed to sync dme-cas3+. Car starts but not run.
  6. #95
    Dec 2018
    If i want to copy a rangerover remote, the app says „put the unlocked working key on the bav-key adapter „. How to unlock a working remote and do i need to lock it at the end?
  7. #96
    Feb 2014
    Quote Originally Posted by Alpaholic View Post
    Don’t worry just put the working key in the BAV unit it just stops you from cloning this key.
    the key will be fine after
  8. The Following User Says Thank You to doolittle For This Useful Post:
    Alpaholic (20th October, 2021)
  9. #97
    Feb 2014
    [QUOTE=smokey08;4196985]Tried this function on my discovery sport. Worked perfectly with a xhorse smart key. Even the emergency start worked when I removed battery from fob and placed on bottom of the steering column. Original key was unlocked and KVM is FK72-19H440
    the Xhorse keys work fine but I can’t get the londor keys or editable keys from autokeys to clone.
    anyone had luck.?
  10. #98
    Mar 2018
    UK
    Today I tried to copy RR Sport 2016 but on my LR menu there is not option to clone the keys like on youtube videos
    The app is up to date
    How to activate this function that must be free if you have JLR module?
  11. #99
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by doolittle View Post
    anyone had luck.?
    I would try changing the ID to match a slot in the KVM with another programmer then try to program with ACDP.
  12. The Following User Says Thank You to smokey08 For This Useful Post:
    doolittle (27th October, 2021)
  13. #100
    Dec 2018
    Quote Originally Posted by smokey08 View Post
    What kind of programmer to change the id can you recommend?
  14. #101
    smokey08's Avatar
    Essex, UK
    I would try with vvdi, should be the first few bytes of the keys eeprom
  15. The Following User Says Thank You to smokey08 For This Useful Post:
    Alpaholic (26th October, 2021)
  16. #102
    Dec 2018
    Quote Originally Posted by Manta1600 View Post
    I downloaded the app last week, its there. No activation was needed.
  17. The Following User Says Thank You to Alpaholic For This Useful Post:
    Manta1600 (26th October, 2021)
  18. #103
    Mar 2018
    UK
    I'm with ver 3.0.101 and I can't find higher version
  19. #104
    Dec 2018
    Got the same version. Resource vision 327. There must is a menue on the third position called „OBD dublicate key“.
  20. #105
    Dec 2018
    Tried a BMW 320 11/2016. Original remote is the 5767 with pcf7953. I did not had this remote. I tried a lot of 7945 ond some 7953 from chine. I did not work. I read the remotes and they are "unlocked". But the key numbers are programmed. I can see them in the slots.
