Results 1 to 7 of 7
    negative2323's Avatar
    Dec 2015
    Europe
    Default Nissan rogue 2016 hitachi meb403-000 help needed..
    Hello DK..
    There was a topic few month ago with the same isue, but i decided to start a new one.
    The car nissan rogue 2.5 letrol 2016 with hitachi meb403-000A ecu.. the problem is that there is no synchro between ecu and bcm, even if to rewrithe keys.. there is only one dtc in ecu P161F.. so need to virgineze the dump of ecu for new ecu installation procedure.. if some one have expirince pls contac with me.. i will post the rom.
    Thanks a lot..
    Wbr Maxi
    Aug 2015
    hi, i have same problem working, on it half year
    Dec 2015
    Europe
    Did you Found the solution ?
    There was one guy on this forum who had the solution.. But he didnt answer yet.
    Aug 2015
    no, not found, i will pay for solution,
    Dec 2018
    hi Did you Found the solution ??
    i have same problem
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Any news? How to virginize this ecu?
    Russia, Kirov
    If you have mmcflash - i can do it
